Community Member
Route Redistribution into RIP
I set a home lab as illustrated in the topology (screenshot.jpg).
In the accompanying book, it says that, after redistributing 172.12.13.0/24 and 172.12.34.0/24 into RIP, there should not be a RIP route. It says that it's due to the default seed metric value.
However, in my lab, I could see a RIP route on router R2.
As for redistribution, I did the following under R1:
"router rip
redistribute ospf 1
redistribute connected1
Is there something wrong with my redistribution?
Hall of Fame Super Silver
Re: Route Redistribution into RIP
Hello Wassim,
the route you see on R2 is 172.12.0.0/16 that is the major network to which subnets 172.12.13.0/24 and 172.12.34.0/34 belong.
RIP has the auto-summary feature so on major network boundary the major network is advertised for the presence or redistibute connected.
If you disable auto summary with
router rip
no auto-summary
you should see net 172.12.13.0/24 only, probably the seed metric is required when redistributing from a dynamic routing protocol and so red connected and may be red static are an exception to this rule.
to see this remove also the red connected inside the rip process without defining a seed metric: if no network command is present on R2 also the subnet 172.12.13.0/24 should disappear.
when you set a seed metric for ospf 1 redistribution into rip or simply you use:
default-metric 2
the ospf subnets should appear
Hope to help
Giuseppe
Community Member
yes indeed, it was the major network advertised by RIP on R1.
I did a little search about redistributing into RIP and here's the rule:
by default, every route redistributed into RIP has a seed metric value of Infinity, EXCEPT for static or connected routes. These ones enter with a seed metric of 1 by default.
The OSPF route doesn't appear in R2's routing table because of Infinity.
As you mentioned, Giuseppe, I need to specify either a seed metric default value (for all redistributed routes) or a seed metric within the "redistribute" command for OSPF
thanks
290
