You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
Route selection by Prefix length or AD
suppose i am getting two routes from one from ospf and one from EIGRP. and ip getting maximum prefix match with ospf then which route it will select... OSPF or EIGRP.
  • WAN Routing and Switching
Hall of Fame Super Silver
Re: Route selection by Prefix length or AD
Hello Irfan,
the most specific route is used.
if both protocols propose the same prefix and prefix len the lower AD is installed in the routing table.
Hope to help
Giuseppe
Thanks friend...
then there is no meaning of AD if the maximum match prefix route is coming from higher AD...
Hello Irfan,
most specific route first
AD is looked at to break a tie in prefix length
Hope to help
Giuseppe
162
