Community Member
Route tracking using IP SLA objects
I have few questions.
1) if i am sending 5 packets after every 1 minute, then Is the object failed if even a single packet loss and other 4 replied.
2) After how much time it changes the route after the object actually failed?
Blue
Re: Route tracking using IP SLA objects
I believe that is what the threshold command is for. It sets the number of failed SLA monitor events that can occur before the alternate route is taken.
Community Member
Thanks.
if i am sending 10 packets, 9 were successully recieved and 1 failed. so will the track object will fail or no?
Any documentation for this will be a great help.
Community Member
http://www.cisco.com/en/US/docs/ios/12_4/ip_sla/configuration/guide/hsthresh.html#wp1027184
See "Configuring Threshold Violation Types for IP SLAs Reactions" section.
Community Member
Thanks.
This document related to the routers but in my setup i have cisco ASA firewalls and these doesnot have the configuration like one present in the document. Although the document you have supplied is very good but didn't help me out in my scenario. Can you please help me out in respect to firewall.
Community Member
Hey,
Sorry, I can't help you with ASA's, I have only Check Point experience.
Sorry,
Ryan
Community Member
Maybe this link will be helpful regarding route tracking on the ASA:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
I havent done this on ASA before, so I'm not sure how the packet loss is handled regarding the frequency/threshold/timeout. I can imagine the tracked object only failing if all the packets go misssing, but you should try it out in a lab to be 100% sure.
Hth
751
