Webcast-Catalyst9k
Router 1720 question
Hi, I've read that the 1720 router support connections up to 2048 Mbps. Is this the limitation of the router or the interface? I mean, can I have 2 serial interfaces both 2048 totalizing 4096 Mbps?
1 REPLY
Re: Router 1720 question
It looks like, per wic you get 2.048 mbps on a wic-1t. So you should be able to get 2.048 mbps on each port. Realistically whether you will get that much b/w on each port, is still a question to me.
http://www.cisco.com/en/US/products/hw/modules/ps2641/products_installation_guide_chapter09186a008007cb4a.html
100
