Router 1841 with ADSL
Please,
I need of configuration example to router 1841 with ADSL(static ip address)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Router 1841 with ADSL
Enter "ADSL PPPoE example" in CCO search box, click first hit.
You need to ask your ISP if they use PPP or not. And if the don't, if bridged our routed encapsualtions (generally is first, preferrable is the second).
In any case, you can enter "ADSL configurazion example" in the search box topright corner.
They are using PPP.
The problem is that my router 1841 have only interfaces fastethernet and not ATM. Thanks
Enter "ethernet pppoe example" in CCO search box, click first hit.
243
