Router 2801 does not function
I have a 2801 routeur with 2 cards, WIC ADSL and WIC1T.
I have configured my router with sdm and it doesn't function.
I want that the DSL line like backup.
I give you my conf.Could you please help me because it's very urgently
In advance thank you.
Building configuration...
Current configuration : 4875 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Router
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
enable secret xxxx
no aaa new-model
resource policy
clock timezone PCTime 0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
ip cef
ip tcp synwait-time 10
no ip dhcp use vrf connected
no ip bootp server
ip domain name yourdomain.com
ip ssh time-out 60
ip ssh authentication-retries 2
crypto pki trustpoint TP-self-signed-369948791
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-369948791
revocation-check none
rsakeypair TP-self-signed-369948791
crypto pki certificate chain TP-self-signed-369948791
certificate self-signed 01
3082024B /*...(a serial of number)*/
quit
username admin privilege 15 secret xxxx
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
ip address X.X.X.X 255.255.255.252 secondary
ip address Y.Y.Y.Y 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface ATM0/1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/1/0.3 point-to-point
shutdown
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Serial0/2/0
ip address Z.Z.Z.Z 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
clockrate 2000000
interface Dialer0
ip address dhcp client-id FastEthernet0/1
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname XXXXXX
ppp chap password 7 XXXXXXXX
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/2/0
ip route 0.0.0.0 0.0.0.0 ATM0/1/0.3 250
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Serial0/2/0 overload
ip nat inside source list 2 interface Serial0/2/0 overload
logging trap debugging
access-list 1 remark INSIDE_IF=FastEthernet0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 81.192.64.128 0.0.0.15
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
1 ACCEPTED SOLUTION
Re: Router 2801 does not function
I haven't worked with SDM.
If you see traffic for ethernet interface and not for Serial interface in SDM, then it means that no traffic is flowing via the serial interface. Check the output of the show interface command and cross check with the settings in the SDM.
Rate the posts, if they were helpfull to you.
-VJ
You have a "shutdown" statement under your ATM0/1/0.3 interface.
Issue a "no shut" for that interface.
Also your floating static route should point to the dialer interface not the ATM interface.
Hence remove the route "ip route 0.0.0.0 0.0.0.0 ATM0/1/0.3 250 " and add the following floating static route.
ip route 0.0.0.0 0.0.0.0 dialer0 250
Hope this helps. Rate if you find it usefull.
-VJ
Thank you very much for your speedly answer.
But i have a pb with my wic1T cards.
Through the T1 line i don't have internet.
Please help me
Thanks for the update.
What is the problem that you are facing with the t1 line now.
Are you able to ping the other end serial ip from the router?
Can you check the "show interface" output of this link and see if you have any error.
Get back to us with your observation.
-VJ
thank you,
My T1 line is ok, I have internet.
I'll test later the DSL line.
But i have any questions.
When i see the interface serial monitor(in sdm)there is nothing, it's normally?(after the router i have a pix 515)
Because when i see to the ethernet interface i have something in the graph.
-VJ
Hi you're right.
I maked a show interface and it'ok.
Thank you very much for this help.
You are very obliging
Good continuation
131
