Router 2801 Error show flash
bagnolini
On my 2801 I've got thi issue:
2801Voice_Gateway_MI#show flash:
%Error show flash: (No device available)
2801Voice_Gateway_MI#show version
Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 12.4(6)T7, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 29-Mar-07 05:41 by khuie
ROM: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
2801Voice_Gateway_MI uptime is 46 weeks, 1 hour, 18 minutes
System restarted at 09:38:26 CEST Mon Aug 24 2009
System image file is "flash:c2801-spservicesk9-mz.124-6.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2801 (revision 4.1) with 235520K/26624K bytes of memory.
Processor board ID FCZ091622WG
2 FastEthernet interfaces
4 ISDN Basic Rate interfaces
1 DSP, 8 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
Can you help me?
Leo Laohoo
You sure the CF wasn't ejected by accident?  Uptime of 46 weeks.  Either the CF is faulty, the CF slot is faulty or someone pulling a prank and the CF was ejected.  Manual intervention is the way to go.
wang baojun
hello ,
the problem seem happen like in simulation dynamic router , the real router ,i have no idea . you can try reboot the C2801.
or the flash card was broken .maybe.
SHF#show flash
System flash directory:
File  Length   Name/status
  1   15194664  c2600-ik9o3s3-mz.122-15.T12.bin
[15194728 bytes used, 1058200 available, 16252928 total]
16384K bytes of processor board System flash (Read/Write)
SHF#show flash
  1   15194664  c2600-ik9o3s3-mz.122-15.T12.bin [deleted]
SHF#squeeze flash:
Squeeze operation may take a while. Continue? [confirm]
squeeze in progress... eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Squeeze of flash complete
SHF#show flash
No files in System flash
[0 bytes used, 16252928 available, 16252928 total]
From the show version output, it seems like the flash card is not recognized by the hardware. Most likely it is a bad flash card issue or it could be a bad slot on the router as well. If you have a spare flash (know to be good) card, please try it on the router. If that is also not recognized, I would suspect the router itselve. You might have to get the router replaced.
Hope this helps.
NT
Leo Laohoo
I've changed the flash and now evwrything is ok
thanks
