Router 2811 port problem
I am trying to work on the Cisco Packet tracer 5.0 for some time now.. But everytime i configure an interface and then verify it show the "show" command. I am getting an information displayed that says the port is disabled .. Can anyone please provide me with the solution for this problem. For a better view of the problem please check the attachment.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Router 2811 port problem
Hello Vishal,
by default interfaces are admin down
do
int ser1/0
no shutdown
to be able to use it
Hope to help
Giuseppe
Hello Vishal,
do
int ser1/0
no shutdown
Hope to help
Giuseppe
I have issued the "no shut" command a number of times but still i am getting the same problem.. You can see it for yourself in the attchement..
Hello Vishal,
now is different the serial interface is down/down
before it was admin down/down.
A serial interface to be up/up needs to be connected to some device that makes leads to be up:
at the end of the show you see:
DCD down carrier
DSR down
CTS down
these are from L1 DCE
DTR and RTS are from the router serial interface
see the following from a router in production
sh int ser4/2
Serial4/2 is up, line protocol is up
446 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
if you are connecting two routers in back-to-back one has to provide clock:
use
clock rate 2000000
Hope to help
Giuseppe
Silver
by default all ports are disabled.
you must go under the port and use the command "no shutdown"
then the port will be activated.
139
