Router 3660 not sensing 16 port A/S Module .
Hi , i am facing a typical problem that cisco 3660 is not able to activate the 16 port A/S Module .
Following is the Message i get when the router boots !!
16 A/S is in slot 2 and is a new module .
MEMINIT: No iomem table entry for pa type 0x391 in slot2
3660 Chassis type: ENTERPRISE
1 FastEthernet/IEEE 802.3 interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
00:00:04: %PA-2-UNDEFPA: Undefined Port Adaptor type 913 in bay 2
00:00:04: %PA-3-DEACTIVATED: port adapter in bay [2] powered off.
IOS Version :
IOS (tm) 3600 Software (C3660-D-M), Version 12.1(21), RELEASE SOFTWARE (fc1)
What may bethe problem ? Pls help ?
Re: Router 3660 not sensing 16 port A/S Module .
Hi Murthy
AFAIK you need to upgrade the current ios code so that your router can recognize the card.
regds
You need atleast Cisco IOS Release 12.2(15)ZJ or Release 12.3(2)T or a later release to run this module on 3660 router.
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps5207/products_feature_guide09186a0080181b66.html#1027188
http://www.cisco.com/en/US/products/hw/routers/ps274/products_qanda_item09186a00801850cd.shtml
HTH,Please rate if it does.
-amit singh
116
