Router 3660 PPPoE BRAS
I'm configuring C3660 for PPPoE subscribers. I'm just trying to use feature ”range [range-name] pvc start-vpi/start-vci end-vpi/end-vci” under ATM interface configurations.
Router(config)#interface atM 1/0.4 multipoint
Router(config-subif)# Here I can't find “range” command.
I tried different IOS version 12.2 and 12.3, but it did not help. I'm running now with c3660-telcoentk9-mz.123-22.bin. Can someone please confirm the support of range command under ATM interface in 3600 series routers.
Hall of Fame Super Gold
Re: Router 3660 PPPoE BRAS
these BRAS features are found in 12.2SB, but there is no released image for the 3660.
In case I just want to use range command feature under ATM configuration. Is it necessary to get 12.2SB. ATM range command feature is an important feature and I would it should not be with specific release.
according to the documentation, the command is supported only on 12.2 SB and consequently only on the platform supporting 12.3 SB.
338
