Router 827 and 857
Please may anybody help me understand why the following configuration was working fine on the 827 router and it is not working on the 857 router?
I was accessing my web server perfectly with the 827, from the Internet.
Now, with the 857, I access it only from the internal LAN.
Thank you.
Re: Router 827 and 857
I can see from the below config on your device that there is an ACL 75 applied to allow HTTP access for 192.168.0.10 and 192.168.0.15 IP. are you trying to access device from internet using only these 2 IPs?
If not, I feel you won't be allowed to acecss it from internet.
no ip http server
ip http access-class 75
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
access-list 75 permit 192.168.0.10
access-list 75 permit 192.168.0.15
also i can see "no ip http server" configured. try to enter "ip http server" to enable HTTP.
hope it helps ....
the server web you are mention is the router server web, but I have problem to reach the server web wich it is in a PC: 192.168.0.150.
I don't think I should activate it. What do you think.
The configuration is OK and looks fine to me. There are two things that we can try:
1. From the internet try telnetting to the Dialer IP and see if the request reached the Web server. Got to command prompt and do " telnet 80 " if you see a blank black screen that means the request is reaching the web server.If its not then we have to try troubleshooting that.
2. Try clearing the Nat translation table and also try to remove the NAT configuration and try to put it again.Write mem and Reload the router.When it comes back, check if it works or not.
-amit singh
Ok amit-singh, I will do it tomorrow, Here is 9,00 pm I am not able to do it right now.
I will try to contact you again.
Thanks for your collaboration
Giovanni.
Hell? amit-singh, I did the test you suggested to me and it was positive as you said I saw a blank black screen and I reached my web server typing the ip address and port 80.
This means the ddns is not solving the name - ip address.
What do you think?
Note!
I wrote: hello not hell.
117
