Router 887 no puedo conectar con ADSL
Hola a todos
Tengo un router 887va-k9 y quiero reemplazar mi modem para lo que necesito conectar la linea adsl al equipo; lo he configurado pero no tengo salida a internet..
Esto es lo que le he configurado mi interfaz atm levanta me asigna la ip pero no tengo salida a internet, alguna idea???
Gracias.
SHOW RUN
Building configuration...
Current configuration : 1971 bytes
! Last configuration change at 17:53:50 UTC Mon Mar 26 2012
! NVRAM config last updated at 17:53:52 UTC Mon Mar 26 2012
version 15.1
no service pad
hostname uclah
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
--More--                           ip source-route
ip dhcp pool pool1
import all
network 192.168.1.0 255.255.255.0
dns-server 8.8.8.8
lease 2
ip cef
no ipv6 cef
vpdn enable
vpdn-group pppoe
license udi pid CISCO887VA-K9 sn FTX161081P3
username wixnet privilege 15 secret 5 $1$3TVH$NhA64raulfRi2/nzaiaN51
--More--                           !
controller VDSL 0
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 8/81
  encapsulation aal5mux ppp dialer
--More--                             dialer pool-member 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip nat inside
ip virtual-reassembly in
interface Dialer0
ip address negotiated
ip nat outside
--More--                            encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname USER@ISP.net
ppp chap password 0 XXXXXXX
ppp pap sent-username USER@XXX password 0 XXXXXX
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
line con 0
--More--                           line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
end
Hall of Fame Super Gold
Re: Router 887 no puedo conectar con ADSL
int dialer0
ppp ipcp route default
or
ip route 0.0.0.0 0.0.0.0 dialer0
Gracias Paolo ya agregue esa ruta estatica pero sigue sin funcionar, agrego el estatus de mis interfaces tambien:
uclah#SHOW RUN
Current configuration : 1933 bytes
! Last configuration change at 23:14:03 UTC Mon Mar 26 2012
version 15.1
no service pad
hostname uclah
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip dhcp pool pool1
import all
dns-server 200.33.146.202 200.33.146.194
lease 2
ip cef
no ipv6 cef
vpdn enable
vpdn-group pppoe
controller VDSL 0
interface Ethernet0
no ip address
interface ATM0
no ip address
pvc 8/81
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip nat inside
ip tcp adjust-mss 1452
interface Dialer0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username USERRR password 0 XXXXXXX
ip http server
ip route 0.0.0.0 0.0.0.0 Dialer0
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
end
uclah#
show ip int br
Interface                  IP-Address      OK? Method Status                Protocol
ATM0                       unassigned      YES NVRAM  up                    up
ATM0.1                     unassigned      YES unset  up                    up
Dialer0                    unassigned      YES NVRAM  up                    up
Ethernet0                  unassigned      YES NVRAM  administratively down down
FastEthernet0              unassigned      YES unset  down                  down
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  down                  down
FastEthernet3              unassigned      YES unset  up                    up
NVI0                       unassigned      YES unset  administratively down down
Virtual-Access1            unassigned      YES unset  up                    up
Virtual-Access2            unassigned      YES unset  up                    down
--More--                           Vlan1                      192.168.1.1     YES NVRAM  up                    up
uclah# show ip int br
uclah#
No se si la interfaz NVI0 tiene algo que ver no encuentro como ponerla UP
446
