Router and policy
Hi!
If I use policy on ethernet for packets marking and if I use NAT ... wich is applied first? What policy for marking see? Original address or nat-ed address?
Thanks!
  • WAN Routing and Switching
Re: Router and policy
Before you can understand the NAT Order of Operations list,
you first need to understand NAT itself.
In its most basic form, NAT translates one IP address to another IP address.
When the router uses this order of operations, it takes the
inbound packet, starting at the top and moves down the list. If the packet is
from a NAT inside-designated interface, it uses the inside-to-outside list. If
the packet is from an outside-to-inside interface, it uses that list.
Here's the order of operations for the inside-to-outside list:
If IPSec, then check input access list
Decryption—for Cisco Encryption Technology (CET) or IPSec
Check input access list
Check input rate limits
Input accounting
Policy routing
Routing
Redirect to Web cache
NAT inside to outside (local to global translation)
Crypto (check map and mark for encryption)
Check output access list
Inspect context-based access control (CBAC)
TCP intercept
Encryption
Here's the order of operations for the outside-to-inside list:
Decryption—for CET or IPSec
Input accounting
NAT outside to inside (global to local translation)
Policy routing
Routing
Inspect CBAC
TCP intercept
Encryption
HTH,
if it does, please rate this post.
Vlad
hi,
you will find how the NAT works in order on this link:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080133ddd.shtml
rate the psot if it helps
regards
Devang
I still do not get it. Eth int will be inside and wan interface will be outside. From documentation I can see that queuing is last. But if I have policy for packet marking and that policy use access lists to inspect what are the sources and mark packets acordingly, will those access list see translated address?
I would say, yes. the queueing configuration need to reflect the NAT configuration.
Anyone, are you configuring this in a production environment? or testing first on a LAB?
Try it and let us know.
and Please rate any helpful posts.
Vlad
:-)) lab!? what is that? test environment? :-)) just joking, of course I so not have lab to test it. I will have this config tommorow in production and will see. Never mind, I'll find a way, put both adresses in access lists and see. thanks
108
