05-02-2007 01:06 PM - edited 03-03-2019 04:47 PM
I have a cisco 2620 and a 4nm async/sync acting as frame relay switch. I have the connections setup but what I'd like to do is set the switch (router) up to send fecn/becns once the traffic reaches a certain limit. Basically I want to set the CIR on the frame switch and enforce it similar to what a provider would do.
Thank you.
Dan Cox
05-02-2007 01:18 PM
Sorry, CIR and congestion management is not supported on the frame-relay switching feature.
05-02-2007 01:21 PM
I don't think that this can be done on a Cisco router acting as a frame relay switch,
HTH, please rate if it does help,
Mohammed Mahmoud.
05-02-2007 06:44 PM
Hi, Dan
Don't give up anyway. There is an old book called : Cisco Frame Relay Solution Guide.
You may find your answer on this book, chapter 6, "Configuring Frame Relay Switching Enhancements on a Cisco Router"
There are some configuration examples on topics you have mentioned. Have a look at this site:
http://safari.adobepress.com/1587051168/ch06lev1sec3
Good Lucks
SSLIN
05-03-2007 03:49 AM
Good finding. I kind of remember, shaping and policing are supported, but not congestion notification...
