Community Member
router boots into (boot) mode
Config-register is set to 0x2102.
when I pull the PCMCIA out and reload the router, it come up in boot mode.
This is really bad and I would prefer it boot into rommon> and loos all functinality. rather that have some features but not others.
Is there a register setting that will force the router with no valid image to go into rommon instead of boot mode?
1 REPLY
Purple
Re: router boots into (boot) mode
Hi Todd,
I don't believe there is any setting that will allow you to do so. The router will always fall back to the boot image, if one is available.
Hope that helps - pls rate the post if it does.
Paresh
108
