Community Member
router c1700 serie in rommon mode
I think the flash is corrupted any refuse confreg 0x2102 or 0x2142....
need help.
thanks
Re: router c1700 serie in rommon mode
What happens when you try to access flash using " dir flash:"
Do you access it and see any file in there?
-amit singh
Community Member
I do but show me that there is a file name like startup-configt instead of c1700-mz...bin
nothing in all confreg setting
can you try giving boot command under the rommon prompt.
Once you are done it should boot normally and get you to the router prompt.
Once you are there in the router prompt you can check out for the confreg and change the same..
regds
I believe you dont have the required image in the flash, that's why the router is in rommon prompt.Please use the document below for recovering the router from rommon :
http://www.cisco.com/en/US/products/hw/routers/ps221/products_configuration_guide_chapter09186a008007cd0e.html
HTH,Please rate if it does.
-amit singh
128
