Router Enable mode
Arifuddinkhaja
Hello!
I have a query..
When I telnet to Router I enter into config mode directly!?!?. I want to enter into privilege mode.
check out da below configs.
version 12.4
no service pad
hostname XXXXXXX
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no logging monitor
enable password XXXXXXX
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip wccp web-cache
ip cef
Correct me if am wrong..
Your prompt feedback on this will be very much appreciated.
Many Thanks!
9 Replies 9
paolo bevilacqua
Most part of your config is missing.
Plase do not solicit for timely answers as this is a freely supported forum, if you need strictly time-bound support, get a support contract.
Hi!
Thank alot 4 ur valuable suugestion.
Pls find below complete configs and suggest me on dis.
version 12.4
no service pad
hostname xxxxxxx
boot-start-marker
boot-end-marker
no logging monitor
enable password xxxxxx
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip wccp web-cache
ip cef
no ip dhcp use vrf connected
ip dhcp pool xxxx
no ip bootp server
ip domain name xxxxxx
voice-card 0
policy-map qos
class voice-traffic
  bandwidth 256
class class-default
interface Tunnel0
description xxxxx
ip address xxx.xx.xx.x  xxx.255.255.xxx
load-interval 30
tunnel source xx.xxx.x.xx
tunnel destination xxx.xx.xxx.xxx
interface FastEthernet0/0
description conection to pix
ip address xxx.xxx.xx.xxx 255.255.255.0
ip access-group 101 in
no ip redirects
no ip unreachables
ip accounting  output-packets
ip flow ingress
ip route-cache flow
ip tcp adjust-mss 1300
load-interval 30
duplex auto
speed auto
interface FastEthernet0/1
description connection to xxxxxxxx
ip address dhcp
load-interval 30
duplex auto
speed auto
service-policy output qos
interface Serial0/3/0
no ip address
encapsulation frame-relay
clock rate 2000000
frame-relay lmi-type cisco
interface Serial0/3/0.1 point-to-point
ip address xx.xx.xx.x 255.255.255.252
frame-relay interface-dlci xxx
interface Serial0/3/0.2 point-to-point
description national link
ip address xxx.xxx.xx.x 255.255.255.252
ip classless
ip http server
ip http authentication local
ip http secure-server
ip http  timeout-policy idle 60 life 86400 requests 10000
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/2/0
voice-port  0/2/1
dial-peer voice 1 pots
preference 1
destination-pattern 10
port 0/0/0
dial-peer voice 2 pots
preference 2
port 0/0/1
dial-peer voice 3 pots
preference 3
port 0/0/2
dial-peer voice 4 pots
preference 4
port 0/0/3
line con 0
login local
line aux 0
line vty 0 4
access-class 1777 in
exec-timeout 60 0
privilege level 15
password xxxx
login
transport input telnet
line vty 5 15
privilege level 15
password xxx
login
transport input telnet ssh
line vty 16 807
password xxxx
login
end
Thanks!
Not sure what your definition of privilege and config mode is but from what I understand you are directly landing into enable mode and you want to land into user mode instead. If this is the case then remove the 'privilege level 15' commands from your vty line configuration.
line vty 0 4
no privilege level 15
Hi Atif!
Thanks 4 ur response.
My query is: When am trying to telnet into the Router, am directly landing into privilege mode i.e. R# instead of landing into User Mode i.e. R>
So wn I telnet I need 2 land into USER mode. Pls suggest me on dis.
Thank 4 ur support and Kind cooperation!
Please follow the guidelines I provided in my previous response. You need to remove the 'privilege level 15' command under the line vty in config mode.
I tried but it's of no use...
Well that is the way to do it. I am not sure of the exact configuration commands you typed in so just providing them below for information:
config t
line vty 0 4
line vty 5 15
Disconnect from the router after configuring the above and establish a new telnet session. You should land into user mode.
Atif
Please try the following:
line vty 0 4
privilege level 0
exit
That should fix it.
NT
k_srinadh
Please configure following Line VTY..
Go to Config t mode..
line vty 0 4
password cisco
login local
If you want UN & PASSWD
then configure in Conf terminal mode
username cisco password cisco
Hope this Helps.
Srinadh.
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
