10-01-2008 11:21 AM - edited 03-03-2019 11:45 PM
I have a 2600 router, whenever I config the router and save the running config to startup config and if the router should reboot all my config is lost, how can I fix this prob??
Solved! Go to Solution.
10-01-2008 07:58 PM
10-01-2008 11:25 AM
Sounds like you may well have the wrong config reg value. The one you want is 0x2102. See this attached link for details -
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800a65a5.shtml
Jon
10-01-2008 01:06 PM
Thx for the help.
10-01-2008 01:11 PM
No problem - you got it working then ?
Jon
10-01-2008 04:26 PM
yes, the router is ok now.
10-01-2008 07:28 PM
Shane
If you have a problem, and if Jon has supplied an answer that guides you to a solution to your problem, then it would be appropriate if you would use the check box function in this thread to announce that this problem is resolved and to award Jon 5 points for providing a solution that resolved your problem.
I have done what I can about points. It would be nice if you would do what you can with the check mark and with points.
Rick
10-01-2008 07:58 PM
Rick
Much appreciated.
Jon
10-13-2008 07:54 AM
Sorry was in China, and alway from my laptop. Sorry
