Router going to ROMMON after IOS update but then boots with "boot flash:"
I've very strange problem on 3725 router. I've updated it from 12.3(9) IPBASE to 12.4 IPBASE+K9 IOS version.
First of all, I've tried:
- 2 different Cisco 3725;
- 2 different IOS: 12.4(10b) and 12.4(12)
- Updated bootstrap to Version 12.4(13r)T5
- confreg is 0x2102
The problem is:
1. I copy new IOS to flash;
2. I delete old IOS from flash;
3. I reboot router;
4. Router goes to ROMMON;
5. I enter "boot flash:IOSNAME" and router boot to normal state;
WHY? Something wrong with IOS on cisco site? How to add or calculate magic number?
System Bootstrap, Version 12.3(10r) [dchih 10r], RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
System Bootstrap, Version 12.4(13r)T5, RELEASE SOFTWARE (fc1)
Copyright (c) 2007 by cisco Systems, Inc.
c3725 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Upgrade ROMMON initialized
program load complete, entry point: 0x80008000, size: 0xa040
loadprog: bad file magic number: 0x0
boot: cannot load "flash:"
slot0: CompactFlash not present.
rommon 1 > dir flash:
Directory of flash:
2640 775134 -rw- C3725_RM2.srec.124-13r.T5
2830 660 -rw- vlan.dat
2 17056536 -rw- c3725-ipbasek9-mz.124-10b.bin
rommon 2 > boot flash:c3725-ipbasek9-mz.124-10b.bin
program load complete, entry point: 0x80008000, size: 0x1044178
Self decompressing the image : ########################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
000259 0X005F3C00 C3725 2NM Mainboard
0002A9 0X001FCE2F 16 port ethernet switch
00039E 0X001E0200 2 port CE1/T1 PRI NM(second generation)
0X003AA110 public buffer pools
0X00211000 public particle pools
TOTAL: 0X00F8BD3F
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 16Mb.
Using 6 percent iomem. [16Mb/256Mb]
Re: Router going to ROMMON after IOS update but then boots with
Since you are able to boot the router using the new IOS image there's nothing wrong with the image. It appears the config register setting may be causing this. Can you verify whether the config register is set to 0x2102. Moreover, if you have a 'boot system' command in the configuration that's pointing to the old IOS image then remove it and make it to the point to the new IOS image or just don't leave any boot system commands in the config.
Sundar
I've opened TAC request about that. So, the answer is: IOS file should be the FIRST on flash. It's not so, it's clear from "dir flash:" in ROMMON.
I Agree with what Sundar says.
As per your post it seems you have uploaded the ios but its not able to take the boot file which you have uploaded, for this you will have togice command
boot system flash:filename.
regards
Mukesh
752
