09-12-2011 02:20 AM - edited 03-04-2019 01:34 PM
Hi All
when i try to saving down configs on router it gives the following mesg ..
R1(config)#wr
Attempting to overwrite an NVRAM configuration previously written
by a different version of the system image.
Overwrite the previous NVRAM configuration?[confirm]
Invalid Pointer value(4589AE30) in private configuration structure
*Sep 12 08:55:30.839: NV: Invalid Pointer value(4589AE30) in private configuration structure
Any idea...
Tash Bhat
Solved! Go to Solution.
09-12-2011 02:25 AM
Did you perform an IOS upgrade before the error message?
Best regards
Giorgos
09-12-2011 03:18 AM
Dear Tabish,
Please do following steps.
1. Save old config template
2. erase startup-config
3. wr erase
4. reload
5. when ask would you like to initial config ?? N
6. paste Old config again
Sure then u will able to save without any errors
09-12-2011 02:25 AM
Best regards
Giorgos
09-12-2011 02:41 AM
Hi Giorgos
no i have not upgraded IOS yet
09-12-2011 02:52 AM
Hi Tash,
Check which IOS version you currently have by using the "sh flash:" command.
Then go to the global configuration mode using the "conf t" command and type
boot system flash:
Where
Best regards,
Giorgos
09-12-2011 03:00 AM
Hi Giorgos,
still it is showing the same mesg
Tash Bhat
09-12-2011 03:08 AM
Could you run the "sh ver" command and tell me what's your current configuration-register?
Thanks in advance,
Giorgos
09-12-2011 03:18 AM
Dear Tabish,
3. wr erase
4. reload
09-12-2011 03:53 AM
THANKS A TON
HTH !!!
it is working fine now!!
