10-31-2014 10:18 PM - last edited on 03-25-2019 03:42 PM by ciscomoderator
my router module hanged in night through which isp connectivity available due to of hwic-2fe module goes down. how i can resolve this problem.
11-02-2014 05:37 PM
FastEthernet0/2/0 is administratively down, line protocol is down 7413439 packets output, 4142244523 bytes, 0 underruns 210455 output errors, 247846 collisions, 1 interface resets
Look at that error:
Check:
1. Physical Cable
2. Speed
3. Duplex
11-03-2014 01:06 AM
GigabitEthernet0/2 is up, line protocol is up Hardware is PQ3_TSEC, address is c464.139b.3002 (bia c464.139b.3002) Internet address is 10.144.15.202/30 MTU 1500 bytes, BW 8192 Kbit/sec, DLY 100 usec, reliability 253/255, txload 17/255, rxload 49/255 Half Duplex, 100Mbps, media type is RJ45 output flow-control is unsupported, input flow-control is unsupported ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 1584000 bits/sec, 207 packets/sec 5 minute output rate 555000 bits/sec, 185 packets/sec 87151 packets input, 89481833 bytes, 0 no buffer Received 0 broadcasts (0 IP multicasts) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 0 multicast, 0 pause input 77346 packets output, 30858545 bytes, 0 underruns 2387 output errors, 356 collisions, 620 interface resets 0 unknown protocol drops 0 babbles, 644 late collision, 1743 deferred 0 lost carrier, 0 no carrier, 0 pause output 0 output buffer failures, 0 output buffers swapped out
What is connected to G0/2? You've got a bad cable.
Serial0/0/0:1 is up, line protocol is up Hardware is DSX1 Description: SLDC-to-PNP-on-E1 Internet address is 10.7.10.3/24 MTU 1500 bytes, BW 512 Kbit/sec, DLY 20000 usec, reliability 214/255, txload 1/255, rxload 1/255 Encapsulation PPP, LCP Open Open: IPCP, CDPCP, crc 16, loopback not set Keepalive set (10 sec) Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 07:47:21 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 1000 bits/sec, 1 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 84615 packets input, 10296370 bytes, 0 no buffer Received 0 broadcasts (0 IP multicasts) 3115 runts, 0 giants, 0 throttles 7218 input errors, 7218 CRC, 0 frame, 0 overrun, 0 ignored, 1337 abort 95542 packets output, 51279812 bytes, 0 underruns 0 output errors, 0 collisions, 242 interface resets 3 unknown protocol drops 0 output buffer failures, 0 output buffers swapped out 1 carrier transitions
WTF.
Serial0/0/1:0 is up, line protocol is up Hardware is DSX1 Description: SLDC-to-JMP-on-E1 Internet address is 10.5.10.3/24 MTU 1500 bytes, BW 512 Kbit/sec, DLY 20000 usec, reliability 246/255, txload 26/255, rxload 1/255 Encapsulation PPP, LCP Open Open: IPCP, CDPCP, crc 16, loopback not set Keepalive set (10 sec) Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 07:47:21 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 23 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 2000 bits/sec, 3 packets/sec 5 minute output rate 53000 bits/sec, 2 packets/sec 267875 packets input, 29162625 bytes, 23 no buffer Received 0 broadcasts (0 IP multicasts) 3308 runts, 0 giants, 0 throttles 7413 input errors, 7411 CRC, 0 frame, 0 overrun, 0 ignored, 685 abort 320838 packets output, 333693996 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 unknown protocol drops 0 output buffer failures, 0 output buffers swapped out 1 carrier transitions
WTF.
I have TWO questions for you:
1. Where did you source your cables from, some hack from e-Bay?
2. Do you actually have a network engineer? A credible network engineer?
The line errors that we've highlighted, that is Networking 101. If no one from your organization saw it then you've got trouble.
