router nat into same address
I have classic situation, router, two interfaces, two ranges A on outside and B on inside, defined some translations and it all works ok. But I have one IP I'd like to be accesses from outside without NAT. I've made translation entry from B3 to B3 and router had no problems, but traffic does not flow. Is this config possible?
Thanks!
Re: router nat into same address
have you also excluded this IP B3 from the normal NAT access-list/route-map? Which entry dis you configure for B3 - can you post the relevant part of your config?
Regards, Martin
no because I have static NAT's
A - outside range
B - inside range
A1 - B1
A2 - B2
and then
B3 - B3
I've tried to catch traffic using access lists. What I can see is that traffic get to the outside interface but do not leaves inbound interface. Outside world is aware of routes to the B network. Debug nat shows nothing.
can you post your config?
Regards, Martin
have you also excluded this IP B3 from the normal NAT access-list/route-map? Which entry did you configure for B3 - can you post the relevant part of your config?
Regards, Martin
P.S.: Gruesse aus Frankfurt!
Hi!
int atmpvc
ip nat outside
int fa0/0
ip addr b.b.b.1
ip nat inside
ip nat inside source static b.b.b.10 a.a.a.10
ip nat inside source static b.b.b.11 a.a.a.11
ip nat inside source static b.b.b.12 b.b.b.12
ok, what do you get with "show ip nat translation"? Is the translation there?
Regards, Martin
yes it is, but when do debug ip nat and do some traffic, there is nothing in logs, and only two left columns of sh ip nat tran are filled, and inbound access list on outside interface shows traffic but outbound access list on eth int does not show traffic. So it is like traffic never past NAT engine
123
