09-12-2008 07:36 AM - edited 03-03-2019 11:31 PM
The internet link is connected into router & it is connected with L3 switch.
The switch & Router is connected with L3 link. In switch default route: ip route 0.0.0.0 0.0.0.0 10.10.100.2 (router ethernet ip).
From switch router LAN interface is pinging but Interne tis not accessing from LAN users pc's. From Router WAN IP is pinging.
Can someone check....
09-12-2008 09:55 AM
Hi Partha,
What is default gateway on user's PC?
09-12-2008 08:49 PM
Default g/w in user pc is their corresponding vlan ip. there are 7-8 vlan's in the switch..
09-12-2008 10:39 AM
Hi Partha,
09-12-2008 10:39 AM
From the router config it looks like the router dont have a route to the Subnet where you user pc's are connected.Add a route for that subnet in the router .HTH.
Ullas
09-13-2008 04:01 AM
if the PCs' subnets are in 10.10/16 the static route is present in the attachment file
ip route 10.10.0.0 255.255.0.0 10.10.100.1
I would use a different access-list using instead of a any source a 10.10.0.0 0.0.255.255
access-list 101 permit tcp 10.10.0.0 0.0.255.255 any eq 80
and so on
It is bettere to be precise in defining what has to be natted.
Hope to help
Giuseppe
09-15-2008 01:44 AM
I made certain changes into the router natting. Now i used a different public ip lan pool allocated by ISP & natted the lan ip segment with that pool.
But there is a serious problem..i can access internet for 10-15 minutes & then internet access is stopped. To make it work router reload is required everytime. ISP link is fine.
Please suggest..
