Router not coming UP
Please, after upgrading a cisco 3660 Router, and reloaded, the Router unit is not coming up again. Can any one kindly help with how to bring up the router?
Many thanks.
1 ACCEPTED SOLUTION
Re: Router not coming UP
You should start the router in rommon (whit key escape sequence)and put the original IOS.
If the router is working correctly after reload with original IOS, then the IOS that you had loaded for upgrade was not accurate.
See Cisco for rommon procedure.
By,
Cristian
Hall of Fame Super Silver
Eriakha
The link that Collin posted is good if the router is booting into rommon. Your post does not supply much detail about what happens when the router attempts to boot. If you would post any messages sent to the console during the boot process it might help us to understand the problem better and to give you better suggestions about how to correct the issue.
Rick
Thank you for your prompt responses. When booting, the router stops after displaying the following message:
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0000B3 0X0009FC00 Dual Port Fast Ethernet
00002B 0X00658200 Two port Channelized E1 (120 Ohm - TP)
000042 0X0009EA00 Four Port Ethernet
0000D8 0X00178610 Dual FE Combo Port Module, 2 WAN
0X000A0000 OIR memory
0X0031F330 public buffer pools
0X00211000 public particle pools
TOTAL: 0X01B8F540
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 28Mb.
Using 10 percent iomem. [28Mb/256Mb]
Nothing else works after this message.
Thank you for offering to assist.
By,
Cristian
270
