12-08-2005 06:26 AM - edited 03-03-2019 11:10 AM
HI,
I have a 1751 router that I have been using for study purposes. I have been booting it from a tftp server because I wanted to used an IOS that supported advance security and it was too big to run from flash along with another file I needed to have in flash. It was working fine until I needed to reset the router to factory defaults. After reconfiguring the router with the exact same parameters as before, it will no longer boot from the tftp server. I've tested both uploads and downloads from tftp and that works fine. I've tried a different tftp software, no different. I'm getting the following error:
SERVICE_MODULE(Serial0/0): self test finished: Passed
%SYS-6-READ_BOOTFILE_FAIL: tftp://192.168.241.9/c1700-sy-mz.122-13.T16.bin File
read failed -- Timed out.
Out put from show run:
Current configuration : 748 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname 1751
boot system tftp c1700-sy-mz.122-13.T16.bin 192.168.241.9
logging buffered 51200 warnings
enable secret xxxx
enable password xxxx
username username privilege 15 password 0 password
memory-size iomem 15
ip subnet-zero
interface FastEthernet0/0
ip address 192.168.241.20 255.255.255.0
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
interface Serial1/0
no ip address
shutdown
ip classless
ip http server
ip http authentication local
line con 0
line aux 0
line vty 0 4
privilege level 15
password xxxxx
login local
no scheduler allocate
end
I'd appreciate any suggestions or ideas.
Thanks!
12-14-2005 07:24 AM
I think the issue is with boot variable.check for the boot variable and give correct boot variable.
12-16-2005 02:09 PM
Make sure the config register is set to 0x2102. You can verify the value of the config register by doing a show ver.
Hope this helps,
