Router or not router
My computer is connect to the internet via an ISP using modem (ADSL). The IP address of my PC is dynamically assigned by the ISP. Now I want to add three more PCs to the network (LAN) so that all of them can access the internet.
1)Can I do it without using a router or HomePNA? If not, what will be the other choices?
2)If, for the above case, a static IP is a must, do I need the static IP for each of the PCs on the (LAN) network?
Re: Router or not router
No, you cannot do it without using a router.
using proxy server u can do this install proxy server on one pc and other two can work through that proxy server.
thanks
usually, your ADSL modem can be a DHCP Server, so you don't need the static IP for each of the PCs.
And one the PC Dial to connect to the internet, so share this connection.
Hi!
What is the OS loaded in ur PC.You may do the following if its XP/2000 or greater:
(1)Install a network card
(2)Enable Internet Connection Sharing(ICS) on the ADSL connection.
(3)The IP will be 192.168.0.1 default
(4)You may give other PCs starting from 192.168.0.2 and gateway 192.168.0.1
(5)Start accessing www.cisco.com............
.......Or, use a cisco 1721 router with WIC-ADSL
Bye
JD
121
