Router Reboot
vishwancc
Level 3
Level 3
Hi ALL:
I have a small doubt
My 2800 router is getting continiously rebooting once i manually reload it ,otherwise it works fine without any issue.
This is the crash info:
CMD: 'control-plane' 11:44:06 IST Sat Oct 3 2009
CMD: 'banner motd C' 11:44:06 IST Sat Oct 3 2009
CMD: 'privilege exec level 1 traceroute' 11:44:06 IST Sat Oct 3 2009
CMD: 'privilege exec level 1 ping ip' 11:44:06 IST Sat Oct 3 2009
CMD: 'privilege exec level 1 ping' 11:44:06 IST Sat Oct 3 2009
CMD: 'privilege exec level 1 show ip mroute active' 11:44:06 IST Sat Oct 3 2009
Translating "active"...domain server (255.255.255.255)
11:44:06 IST Sat Oct 3 2009: Address Error (load or instruction fetch) exception, CPU signal 10, PC = 0x42372584
From this is conclude 2 thing that after execting command privilege exec level 1 show ip mroute active it reload .
So if i remove this command from the config wil the issue we resolve or i have to upgrade the IOS
Current release Version 12.4(11)XJ
cOMMAND IN RUNNING CONFIG
Chao
Vishwa
paolo bevilacqua
If you want to use that command, you need to update.
Hi P,
Thanks for the reply.
Are you saying that the router is crashing because of that command getting executed.
Vishwa
May be, you would need to confirm with a stack decode.
Wilson Samuel
Level 7
Level 7
Hi Vishwa,
Often the best way to diagnose a Router Crash is to work with TAC.
However, normally I would go ahead and upgrade the IOS after doing a FactFinding on the bugs/issues on the release I have already have and the one I would want to upgrade to.
Hope that helps.
Kind Regards
sam wilson
