Community Member
Router recommendation
Need a router recommendation to handle the performance of a 6mb pipe. Can four T-1's be bonded together to acomplish this? Will a 2811 suffice?
1 REPLY
Purple
Re: Router recommendation
Hi Kirk,
The maximum rated performance of the 2811 is 61MBps. However, the use of multilink PPP is a CPU-intensive operation so you are not likely to get that much out of it.. but then, you only need 6Mbps of throughput.
So in short, I believe the 2811 will handle it. In order to treat the 4 T1s as a single pipe, you will need to use Multilink PPP. The following link describes MPPP configuration:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fdial_c/fnsprt9/dcdppp.htm
Pls do remember to rate posts.
Paresh
97
