06-17-2012 08:52 PM - edited 03-04-2019 04:42 PM
Hi All,
I'm facing a really strange issue. I have an old 2621xm router in CCIE lab at home. Only a week ago I started having issue on 2 of them. The problem is on one of them when I go under interface configuration and I type "no shut" nothing happens. Interface stays in administratively down status and when I check running config "shutdown" is still under interface.
On the other one the same problem but only with "router rip" command. I configure my rip routing but then when I check running config there is no rip section and also RIP is not running under "show ip protocols rip".
These routers are connected to 2511 AccesServer. So I thought the issue might be communication from AccessServer to these devices. I connected a console cable straight to them and still the same problem. Everything else is working on these devices.
Has anyone had the same issue before? Any help will be appreciated.
06-18-2012 12:23 AM
Hi Nashvi,
Can you make the interface as default interface and put the configurations one by one and check.
The shutdown command stays in the running config of the interface thats why.
To make interface default,
conf t
default interface gi.....
no shut
exit.
Or can you use this command show post? if yes then please show the output.
Hope this helps
please rate if it helps.
06-18-2012 03:58 AM
Dear Sandeep,
Thanks for the reply. I tried it before but I ran it again to show the output. I even tried re-imaging the device.
R6(config)#default int FastEthernet0/0
Building configuration...
Interface FastEthernet0/0 set to default configuration
R6(config)#do sho runn int FastEthernet0/0
Current configuration : 83 bytes
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
R6(config)#interface fastEthernet 0/0
R6(config-if)#no sh
R6(config-if)#end
R6#show ip int brief
FastEthernet0/0 unassigned YES TFTP administratively down down
06-18-2012 04:08 AM
Hi Nashvi,
Can you connect a device to that port and then try.
Can you try this.
clear interface f1/0 and then try a no shut"
if still now working then might be this is a hardware issue.
06-18-2012 04:24 AM
Hi Sandeep,
There is already a device connected to it and it's still down.
Ok that's fine this might be hardware issue but what about the other router that I'm saying I can go to router rip mode with no error and I can set everything with no error again but when I check running config it's not there. This can't be hardware issue!!! Am I right?
06-18-2012 04:28 AM
Yes ,,,, if its the same router , then 100% its a hardware issue.
You have to change your hardware and then try these commands on other hardware.
06-18-2012 04:39 AM
no it's another router but the same model 2621xm
06-18-2012 04:45 AM
Hi Nashvi,
Usually this router supports RIP configration but there is some problöem in your flash or hardware.
If you can do this then please try.
Step:Try to update the image of the router and then try.
or
Step:Change your hardware and test with new one.
06-18-2012 04:57 AM
As I mentioned in my other post I already updated the image. I will replace the flash tomorrow and will let you know,if by hardware you mean just the flash. Because if you mean the whole router then that's not a solution
06-22-2012 08:51 PM
Hi Sandeep,
I replaced the flash with another known good one. But still the same problem. Also flash doesn't show any erase or write error.
R6#show flash: err
System flash directory:
File Length Name/status
1 29539928 c2600-adventerprisek9-mz.124-3.bin
[29539992 bytes used, 20267364 available, 49807356 total]
49152K bytes of processor board System flash (Read/Write)
Chip Bank Code Size Name erase write
1 1 8917 8192KB INTEL 28F640J3 0 0
2 1 8917 8192KB INTEL 28F640J3 0 0
1 2 8918 16384KB INTEL 28F128J3 0 0
2 2 8918 16384KB INTEL 28F128J3 0 0
03-03-2013 03:17 PM
I found the problem with RIP. RIP configuration won't show in any show command unless we configure at least one interface under the configuration.
But the problem with shutdown interface still exist.
Thanks all.
