Router Stress Test
krishna.vv
HI, I need to figure out what would be the bidirectional bandwidth that the Cisco ISR Routers can support. I have Voice, Video & data running.
Can any one guide me what each ISR router would support for Voice, Video, Data scenarios...
Thanks.
Giuseppe Larosa
Hello Krishna,
use the following router performance portable data sheet.
these are raw data without any feature applied.
Also you need to count twice for bidirectional.
Hope to help
Giuseppe
Hi, Thanks for your reply. Apart from pps what else on the router say NAT, ACL, Policy Maps will bring down the router bandwidth support. I will try to do a bandwidth test with the features enabled and see what bandwidth the router can support say at 60% CPU.
