router synchronization
how a router synchronize speed between router to router speed only 56000kb,
but router to switch speed 10Mb/sec how is manages speed?
Re: router synchronization
Dear Sunix
it depend two your media and connection type
HSSI or FDDI or..
any of them has its specific configuration,
by the way I will attach you a file
hope it helps
in addition to Ehsan's post, in a switch-to-router connection, and if the speed of the switch interface is higher than that of the router interface, which usually is the cause, packets will be buffered and queued in the router based on queuing mechanisms such as fair queueing, FIFO (first in first out), or policy queueing that you configure yourself. If the buffers are not sufficient, packets will be dropped, which you can usually see in the interface statistics of the router (e.g. show interfaces serial0).
Does that make sense ?
GNT
199
