Router-to-router with tunnel doesn' work!
conectividade
Hi, Messrs!
I would like your help! A connection router-to-router with tunnel doesn't work with IOS C3745-ADVENTERPRISEK9-M, Version 12.3(14)T7 and C3745-JK9S-M, Version 12.3 (6a). What could be wrong?
So many differences betwen versions?
What could I do, to do this work?
Attached I send you my config, the other side can't send me a config.
thanks in advance,
Renato
mbacklund2
I think the problem is at line
match address SERVER-CLI
SERVER-CLI don't match to anything in your config. Write a named access-list that match the IP source and/or destination
which should trigg to open the VPN connection.
Take a look in the documentation bellow. That would hopefully help you more.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a008009448f.shtml
If you ensure the access-list is correct for SERVER-CLI, try to remove access-group 170 in/out from s0/0.1 for test.
A full config. can help more.
Hope this helps.
