Webcast-Catalyst9k
Router uBR7246VXR PCI messages
I have a router uBR7246VXR with IOS 12.3(17a)BC1
when I issue the "show version" command I get a messages
show version
cisco uBR7246VXR (NPE400) processor (revision A) with 110592K/20480K bytes of memory.
PCI bus mb0_mb1 has 874 bandwidth points
PCI bus mb2 has 0 bandwidth points
WARNING: PCI bus mb0_mb1 Exceeds 600 bandwidth points
Any ideas what its mean ???
-Tor
1 REPLY
Re: Router uBR7246VXR PCI messages
In 7200VXR routers you have two buses. Each bus has so called "bandwidth points" budget of 600. Each port adapter inserted into router has bandwidth points requirements, i.e. it takes some of the bandwidth points out of the budget.
You have put all your port adapters onto single bus and have overloaded it, while other bus is empty. All you need is to rearrange port adapters so they occupy evenly both buses.
Here are two documents, which provides more details on the topic:
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_configuration_guide_chapter09186a008014cf5c.html
http://www.cisco.com/application/pdf/en/us/guest/products/ps341/c1161/ccmigration_09186a008009184d.pdf
Hope this answers your question.
246
