10-11-2007 03:41 AM - edited 03-03-2019 07:07 PM
I need to replace an old router that has 8 serial V.35 interfaces. I think that a 2800 would do the trick but I am not sure. Any suggestions?
-as
Solved! Go to Solution.
10-11-2007 05:08 AM
Whatch out about the NM-8A/S. It supports a max of 256 kbps in synchronous mode and that is not enough for most circuits.
For ISR router like the 2800 is now available the HWIC-4T and that is would be recommended.
10-11-2007 04:34 AM
hi
If you are talking about NM-8A/S then you can definitely make use of Cisco 2800 series boxes.
For more info on interfaces supported by Cisco 2800 do check this link out .
http://www.cisco.com/en/US/products/ps5854/products_relevant_interfaces_and_modules.html
regds
10-11-2007 05:08 AM
10-11-2007 05:32 AM
Thanks for the tip about the NM-8A/S. The circuits are 2 Mbps, so I will check the HWIC-4T. I imagine I can install 2 of them without problem.
10-11-2007 07:52 AM
You are welcome. The data sheet doesn't mention any limitation in number so you can install as many it fits.
As a recognition to those providing answers, please rate all useful posts using the scrollbox below!
