Router with payload compression and QOS
I have searched for 2 days trying to find information on this subject.  I have a 2851 router with an AIM-COMPR2-V2 module.  The software level is 15.1(4)M7.  We have point-to-point T1 between two of the exact same routers.  I would like to run payload compression, use the AIM module, and enforce a QOS policy on the interface.  The "Show Compress" command counters will not increase as long as the interface has the "Service-Policy Output" command on it.  I found several articles that discuss that as an issue before 12.X versions of software, but I can't find anything newer.
Should this work?  If not, where can I find the most recent documentation as to why it won't?  Also, if not, what is my best option in the given scenario?
  • WAN Routing and Switching
30
