Webcast-Catalyst9k
Routing and Internet
I have a 3825 Router for my T1 connected to a Sonicwall firewall WAN port, then I have a 3550 EMI layer 3 switch connected to LAN port on the firewall.
The 3550 layer 3 switch is used as my internal core router using RIP v2.
3825 Router----(WAN)Sonicwall Firewall(LAN)---Fa0/1 on 3550
Can someone tell me what I need to do to allow users connected to the 3550 and other switches in other vlans to access the internet via the 3825 router?
I know these are stupid noobie questions but that is what I am :)
Bronze
Re: Routing and Internet
As not all devices are participating in a dynamic protocol, a series of static defaults getting back to your 3825 would allow for Internet access. Hope this helps.
Bronze
Hi.
As per your question, you need to defined outgoing route and incoming routes at router 3825,
if this still doesn't work give me more detail ip address and diagram.
rate this post if this help you
86
