09-12-2005 01:42 AM - edited 03-03-2019 10:29 AM
Hi all,
I have a Cisco 2606 router with 2 ethernet interfaces. One of them is connected to the internet. (IP of internetgateway: 192.168.1.1 255.255.255.0) The other interface is connected to a switch with 8 clients, which are in the network : 192.168.0.0 255.255.255.0) How to make it possible to give the clients access to 192.168.1.1.. which routes do i need and how to enter them (newb :) )
Greetz
Heiko
09-12-2005 02:14 AM
hi
i feel u want to enable/extend the internet connectivity to your clients,if you want to connect all your local lan to the internet and allow them to access the net i would suggest to do simple PAT.
just try this commands under your interface which will enable the local to go out and access the net.
interface fastethernet 0/0
ip nat outside
interface fastethernet 0/1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip nat inside source list 101 interface fastethernet 0/0 overload
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
regds
09-12-2005 02:54 AM
Thank you for the fast reply!
The problem is, that ethernet0/0 ist connected to an network 192.168.1.0, where another router with 192.168.1.1 is connected to the internet. When I change ethernet0/0 to 192.168.1.1 there would be a conflict :)
Are there other ways to allow the 192.168.0.0 user on 1/0 to use the 192.168.1.1 router which is connected to 0/0 ?
Greetz
09-12-2005 03:03 AM
is it possible to post out a small/brief topological figure representing the connectivity of your equipments and also the ip address space being used in them at present?
regds
09-12-2005 03:21 AM
Yes sure :
Client 1-8 (192.168.0.10-18)
switch
Cisco 2606 (1/0 :192.168.0.6,
| 0/0 :192.168.1.6)
Internetrouter (192.168.1.1)
other Clients (192.168.1.10-30)
All have 255.255.255.0 as SN
Client 1-8 want to use the Internetrouter :)
Greetz
09-12-2005 03:33 AM
hi
is your default route in 192.168.1.6 router pointing towards 192.168.1.1 ? if not do configure the same.
ip route 0.0.0.0 0.0.0.0 192.168.1.1
And also add route for the client ips i.e., host specific routes since u hve got less amount of hosts to be routed 192.168.0.10-18 towards 192.168.1.6 in 192.168.1.1.
ip route 192.168.0.10 255.255.255.255 192.168.1.6
ip route 192.168.0.18 255.255.255.255 192.168.1.6
regds
09-12-2005 04:46 AM
I agree that there should be a default route on 192.168.1.6 pointing to 192.168.1.1. I am not sure why you suggest a group of host specific routes rather than just having a route like
ip route 192.168.0.0 255.255.255.0 192.168.1.6.
One route is simpler than a group of host specific routes and provides for the possibility that additional hosts may be added to the network at some point.
Or perhaps it would be good to suugest to have a dynamic routing protocol run between the routers to exchange routes?
Rick
09-12-2005 09:18 PM
hi rick
I totally agree with your point in adding a static for the whole /24 address space instead of host specific ,Its good that you have pointed out the same ,i thought of avoiding some kinda recursive lookup for the /24 which is not the case here :-) .
regds
09-12-2005 10:27 PM
Hi all,
I`ve tried to add the routes you suggested, but my
router dont like them... you know why ?
testrouter(config)#ip route 0.0.0.0 0.0.0.0 192.168.1.1
testrouter(config)#ip route 192.168.0.100 255.255.255.0 192.168.1.6
%Inconsistent address and mask
testrouter(config)#ip route 192.168.0.100 255.255.255.255 192.168.1.6
%Invalid next hop address (it's this router)
testrouter(config)#
and
testrouter(config)#ip route 192.168.0.0 255.255.255.0 192.168.1.6
testrouter(config)#
doesnt work, too :(
here is my config :
interface Loopback0
ip address 192.168.42.1 255.255.255.255
interface Ethernet0/0
interface Ethernet1/0
ip address 192.168.1.6 255.255.255.0
router igrp 1
redistribute connected
network 192.168.0.0
ip local pool setup_pool 192.168.0.1 192.168.0.3
ip classless
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
banner motd ^C
Greetz
09-12-2005 10:34 PM
hi
As far as default route is concerned you are adding up it on the rite router (192.168.1.6 which has 192.168.0.0 too),but the route for 192.168.0.0/24 has to be added in 192.168.1.1 router and not in your test router (192.168.1.6).
thts basically added for the reverse traffic to come in to the 192.168.0.0 network.
would suggest to edit ur static route statement similar like this and paste it in your 192.168.1.1 rotuer.
btw with which routers you are running igrp ???
is that between 192.168.1.1 and your router or with something else ?do confirm about that.
regds
09-12-2005 10:56 PM
Hi again :=)
192.168.1.1 is a cheap netgear router without ios... so i cant add a route :( Is there a possibility to solve my problem another way ?
With the standartroute 0.0.0.0 0.0.0.0 192.168.1.1 on 192.168.1.6 router I can ping 192.168.1.1 from the 192.168.0.x clients :) But internet is not working.. As Gateway/DNS I use 192.168.1.1...
Greetz
09-12-2005 11:34 PM
i feel instead of getting more n more complicated , would suggest to configure your cisco box with 192.168.1.1 instead of 1.6.
is it doable ? coz as u said your netgear box may not support whatever other features too if u want work in some of them or to check with.
regds
09-12-2005 11:55 PM
yes you are right. Very complicated. Thank you for your help. Maybe some "playing" with the router helps :=)
And sorry, in my last post I said that I can ping 192.168.1.1... but only 192.168.1.6 is possible.. do you know why ? In my opinion every client in 192.168.1.x should be pingable, if 192.168.1.6 is possible... %)
09-13-2005 12:41 AM
hi
I was wondering about the reachability of your clients (192.168.0.x) to the ip - 192.168.1.1 which u have mentioned in your last mail,and again in your very recent post you have mentioned that clients from 192.168.1.x should be pingable but u have got ur clients in 192.168.0.0 rite ? do clarify ...
regds
09-18-2005 11:39 PM
Hi again,
I have a new plan, because i can´t configure the 192.168.1.1 mashine. Is it possible to do a nat on a cisco 2606 ? I found the option "ip nat...", but i`dont know how to use this option.
Maybe there are a database on inet with FAQ`s or "How to`s" ?
Greetz
