routing discrimination using only NAT , Is it possible ?
Hi everybody
I am dealing to configure correctly one router in order to get that users can reach public ip addresses using a private and the public address at the same time. Is it possible to solve my problem using only NAT ?
Here below you can see the ip nat that I was applying a nat static configuration and I removed it so that users could access directly to the public addresses but now they want keep accessing to the private addresses
ip nat outside source static 57.253.47.1 10.1.74.100 no-alias
Any suggestion would be greatlY appreciated
1 ACCEPTED SOLUTION
Bronze
Re: routing discrimination using only NAT , Is it possible ?
It is not possible to discriminate routing using NAT only. You will have to use policy based routing for this.
Bronze
Thanks a lot for your comments.
105
