Webcast-Catalyst9k
Routing Help - 3640
I am trying to setup my home lab, but not having much luck.  Here is what I have going on...
Cabel Modem ----> Cisco/Linksys Router(192.168.5.1)------->Cisco 3640 (192.168.2.1)
What I want to do is have my internet connection split in to so when I mess with the 3640 I don't interupt the internet connection for the computers outside the lab network.  I has to be something simple, but I can't figure it out.
Here is my running config from the 3640:
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router
ip subnet-zero
ip dhcp excluded-address 192.168.2.1
ip dhcp pool Home
   import all
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
ip dhcp pool 192.168.2.100-192.168.2.254
ip audit notify log
ip audit po max-events 100
call rsvp-sync
partition flash 2 16 16
interface FastEthernet0/0  <---connection from the 192.168.5.0 network
ip address dhcp
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface FastEthernet0/1
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.2.0
no ip http server
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
end
I tried the static route of:
Router(dhcp-config)#ip route 0.0.0.0 0.0.0.0 192.168.2.1
But got this as a result: %Invalid next hop address (it's this router)
Re: Routing Help - 3640
Hi Jonathan,
Try 192.168.5.1 instead:
ip route 0.0.0.0 0.0.0.0 192.168.5.1
Routing Help - 3640
Hi jonathan,
John is right.
Also since you are using dhcp on the switch to get the ip address from your linksys router(dont know why you do that rather than simply confuguring a /30). you also need to have a return route from the linksys router to the 192.168.2.0 subnet.
so on the linksys router have a static route
ip route 192.168.2.0 255.255.255.0 < exit-interface> . The interface is what connects to the 3640 fa0/0 port
Kishore
260
