Routing -Help
Hello Netpro
Diagram attached.
Guest users usually connect to Linksys Access-Point with a WEP Key and access internet.
We need to give Guest users internet connection in another building where Linksys Access-Point
signal are not there.
We have connection from Building one to Building two through Fiber, in the attached diagram VLAN20-switch is in buiding Two.
All LAN users get IP address from Windows DHCP Server for Building One and Building Two.
Another need is LAN users should not communicate with users connected to Internet using Linksys Access-Point.
Can someone help with steps.
1 REPLY
Re: Routing -Help
Do you have any limitations in creating a new vlan for the guest users in the other building?
You can create a seperate Guest vlan terminating the SVI onto the 6500 switch, as a precautionary measure you can apply ACLs onto the SVI interface blocking any communication between the internal vlans and allowing any any to allow internet access to the guest vlan.
regds
198
