Routing issue
mattbashara
I have a point to point t-1 that is currently working for traffic betweeen 192.168.0.0 and 192.168.100.0 (remote site)
I now neet to also route traffic from 192.168.51.0(remote site) and 192.158.50.0. The physical connection to this subnet is there and working and i can ping from both router interfaces but any traffic beyond that times out.
Here are the router configurations.
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
interface FastEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ES_LAN$$FW_INSIDE$$ETH-LAN$
ip address 192.168.0.245 255.255.255.0
ip access-group Any out
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
description $ETH-LAN$
ip address 192.168.50.200 255.255.255.0
ip access-group any out
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface Serial0/0/0:0
ip address 192.168.254.1 255.255.255.0
no cdp enable
router rip
version 2
network 192.168.0.0
network 192.168.50.0
network 192.168.254.0
no auto-summary
ip classless
ip route 192.168.0.0 255.255.255.0 FastEthernet0/0 permanent
ip route 192.168.50.0 255.255.255.0 FastEthernet0/1 permanent
logging trap debugging
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
disable-eadi
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
transport output telnet
line aux 0
login local
control-plane
line con 0
login local
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
privilege level 15
login local
scheduler allocate 4000 1000
and
controller T1 0/0/0
framing esf
linecode b8zs
ip address 192.168.100.252 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
ip address 192.168.51.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
ip address 192.168.254.2 255.255.255.0
no cdp enable
router rip
version 2
network 192.168.51.0
network 192.168.100.0
no auto-summary
ip classless
ip route 192.168.51.0 255.255.255.0 FastEthernet0/1 permanent
ip route 192.168.100.0 255.255.255.0 FastEthernet0/0 permanent
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 192.168.0.0 0.0.0.255
access-list 100 remark SDM_ACL Category=1
access-list 100 permit ip any any
access-list 101 remark SDM_ACL Category=2
access-list 101 permit ip any any
disable-eadi
no cdp run
control-plane
control-plane
line con 0
login local
line aux 0
login local
line vty 0 4
5 Replies 5
Edison Ortiz
1) I recommend removing those static routes you have on both routers. RIP should take care of the networks you want to advertise.
2) Remove those ip access-group under the interfaces. You don't have any corresponding ACL.
mohammedmahmoud
Level 11
Level 11
You should have a route for the ".100" and the ".51" on the local router to the remote ip of the p-to-p "192.168.254.2", and vice versa on the remote router (2 ip routes for ".0" and ".50" back to the wan ip of the local router "192.168.254.1") and not the opposite.
P.S RIP should do it !! you won't be needing static routes.
HTH,
Mohammed Mahmoud.
Richard Burts
Matt
I have checked the configs that you posted and they mostly look good to me. I do note that all of the FastEthernet interfaces apply an access list called any to outbound traffic but that access list does not show up in the configs that you posted. It seems unlikely that it is the cause but it would be helpful to know what is in that access list.
From the configs it looks to me like all the networks/subnets should be in the routing table and things should work. Perhaps you can be a bit more specific about what is not working. Can end stations in 192.168.0.0 network access stations in 192.168.51.0? I would make a guess at this point that it may be an issue with configuration of default gateway on the end stations. One way to check this would be to do an expended ping from your router. In the extended ping specify the destination of the ping as 192.168.51.1 and specify the source of the extended ping as FastEthernet0/1. This will check to be sure that routing between the new networks/subnets is working ok on the router.
Rick
Rick
My take on this:
1. Remove the static routes to the Fa0/0 and Fa0/1 interfaces. They're unnecessary IMHO.
2. Check if the hosts on the other network that you're trying to ping has its firewall turned on and if it's blocking ICMP.
3. Post the output of sh ip route from both routers.
I removed the static routes (thanks for that)
Here are the sh ip results
69.0.0.0/30 is subnetted, 1 subnets
R 69.146.238.216 [120/1] via 192.168.100.1, 00:00:28, FastEthernet0/0
R 192.168.30.0/24 [120/2] via 192.168.254.1, 00:00:10, Serial0/0/0:0
R 192.168.200.0/24 [120/2] via 192.168.254.1, 00:00:10, Serial0/0/0:0
R 199.2.253.0/24 [120/2] via 192.168.254.1, 00:00:10, Serial0/0/0:0
R 10.0.0.0/8 [120/2] via 192.168.254.1, 00:00:10, Serial0/0/0:0
C 192.168.51.0/24 is directly connected, FastEthernet0/1
R 192.168.0.0/24 [120/1] via 192.168.254.1, 00:00:10, Serial0/0/0:0
C 192.168.254.0/24 is directly connected, Serial0/0/0:0
R 192.168.50.0/24 [120/1] via 192.168.254.1, 00:00:10, Serial0/0/0:0
R 192.168.1.0/24 [120/2] via 192.168.254.1, 00:00:10, Serial0/0/0:0
C 192.168.100.0/24 is directly connected, FastEthernet0/0
Other router
Gateway of last resort is not set
R 69.146.238.216 [120/2] via 192.168.254.2, 00:00:10, Serial0/0/0:0
R 192.168.30.0/24 [120/1] via 192.168.0.1, 00:00:02, FastEthernet0/0
R 192.168.200.0/24 [120/1] via 192.168.0.1, 00:00:02, FastEthernet0/0
R 199.2.253.0/24 [120/1] via 192.168.0.1, 00:00:02, FastEthernet0/0
R 10.0.0.0/8 [120/1] via 192.168.0.1, 00:00:02, FastEthernet0/0
R 192.168.51.0/24 [120/1] via 192.168.254.2, 00:00:10, Serial0/0/0:0
C 192.168.0.0/24 is directly connected, FastEthernet0/0
C 192.168.50.0/24 is directly connected, FastEthernet0/1
R 192.168.1.0/24 [120/1] via 192.168.0.1, 00:00:02, FastEthernet0/0
R 192.168.100.0/24 [120/1] via 192.168.254.2, 00:00:10, Serial0/0/0:0
I have verified the ip address I am trying to get to is pingable. (192.168.50.2)
thanks for all lthe help
