Community Member
routing issue
Has someone else see a routing behavior as seen in the trace route above? any idea why:
1. First why does some hops doesn't have the number at the left? as if this does not count as a hop and a TTL decrement.
2. why should this be happening? at the end the packet arrive to the destination.
regards///
Target IP address: 10.139.1.19
Source address: 10.134.10.1
Numeric display [n]:
Timeout in seconds [3]:
Probe count [3]:
Minimum Time to Live [1]:
Maximum Time to Live [30]:
Port Number [33434]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Tracing the route to 10.139.1.19
1 10.134.250.77 0 msec
10.134.250.73 0 msec
2 10.134.250.26 0 msec
10.134.250.34 0 msec
3 10.254.1.97 8 msec
10.254.1.145 0 msec
10.254.1.97 8 msec
4 10.90.3.1 0 msec
10.90.3.17 0 msec
10.90.3.1 0 msec
5 10.90.4.94 26 msec
10.90.4.78 0 msec
10.90.4.94 8 msec
6 10.138.4.5 0 msec 0 msec 0 msec
7 10.138.2.146 8 msec 0 msec 0 msec
8 10.254.7.1 1066 msec 50 msec 42 msec
9 172.16.10.77 42 msec 50 msec 51 msec
10 172.16.10.69 42 msec 41 msec 51 msec
11 172.16.10.66 92 msec 92 msec 93 msec
12 172.16.10.13 92 msec 101 msec 92 msec
13 172.16.101.38 92 msec 101 msec 92 msec
14 172.16.1.194 92 msec 93 msec 92 msec
15 10.139.1.19 101 msec 92 msec 100 msec
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: routing issue
If your phones are not working well do you have QOS on the links to prioritise the Voice related traffic ?
Jon
Re: routing issue
You get multiple entries without an index number where the router has multiple routes to the same destination so it uses both at that hop.
Jon
Community Member
Re: routing issue
thanks Jon,
so this means that this is not a routing loop? is just that packets are going throgh two different routes at this hops.?
Re: routing issue
Your'e correct. If packets get caught in a routing loop they don't break out of it they just go round and round until the ttl runs out.
Jon
Community Member
Re: routing issue
This behavior is normal?
actually PCs are running well, but the voice (phones are not registering) is not working well. Could this be the reason?
Re: routing issue
Jon
Community Member
Re: routing issue
I'll check this on.
thanks a lot..
132
