Routing issue
I need to know how to keep a connected interface from showing up in the routing table. Or have a static route with a higher priority than a connected interface.
Hall of Fame Super Silver
Re: Routing issue
David
I am curious why you need to keep a connected interface from showing up in the routing table? Or to have a static route with a better Administrative Distance than a connected inteface?
I am not aware of any way to keep a connected interface from showing up in the routing table (other than to shut it down - which seems self defeating). I can think of a way to get static routes to take precedence. The connected interface will have a certain subnet mask (for the sake of an example lets assume that it has a /24 mask). If you create two subnets that divide the subnet (so for example create two subnets with /25 masks) then the routing logic will prefer the more specific route and will follow the static route rather than the connected interface.
Rick
Re: Routing issue
If the connected interface is the only one connected from that network, you might consider adjusting the administrative distance the router assigns to that routing protocol. By default a connected interface is at distance= 0 (zero) and a static route is at distance=1 (one). See Doc ID 15986 on Administrative Distance on CCO for more details.
Hope this helps, Please rate helpful posts.
93
