Community Member
Routing on null int
Does this mean that the route to the dest. will be blocked by the null int.
S 213.31.195.206 is directly connected, Null0
Community Member
Re: Routing on null int
the better word is "discarded".
Community Member
No. It does not mean that.
It means that any traffic entering this router destined to that prefix (213.31.195.206) will be sent to the Null0 interface (ie. dropped).
Out of interest's sake, if a subsequent static route points to a static route destination on a null interface (recursive lookup), will that static survive? and just funnel its traffic down the bit bucket?
peter
aksher when ever you are pointing any thing towards the NULL0 then the packet destain for that network will be discarded... in your case packet which is destain for 213.31.195.206 will be discarded...
hope you understand it...
rate this post if it helps
regards
Devang
96
