Community Member
Routing policies ????
hi
why we need to define routing policies ???
what are the requirments for a good Routing policies ,,
Any DOC regarding the routing policies.
1 REPLY
Re: Routing policies ????
One needs routing policy so that one can control the way traffic flows, according to one's own preference, priority. You can define policies so as to make different packets take different path, which you can define as per your choice/needs/preference.
Below are links to some docs -->
http://www.cisco.com/warp/public/732/Tech/plicy_wp.htm
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt1/qcfpbr.htm
Hope this helps...
AbhisheK
Please rate helpful posts!!!
111
