For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
Routing problem between ASA and 2651
I'm having a routing problem between an ASA and a couple of lab routers.
I think the problem is related to firewall/security rules on the ASA, but the packet tracer in ASDM says that nothing should be getting dropped.
I have not configured any additional security rules on the ASA. (full config attached)
I feel like I'm missing something simple here....
Facts:
ASA inside network is 10.30.10.0/24.
R2 is connected directly to the ASA and Fa0/0 has an IP of 10.30.10.20/24.
R2 fa0/1 is directly connected to R1 fa0/1 via x-over cable. 192.168.11.0/24.
R1 fa0/0 is then connected to a switch. 192.168.10.0/24.
My computer is connected to the ASA.
From my computer I can sucessfully ping R1 and R2 using any of its IP addresses, but I can only telnet to R2 using 10.30.10.20.
If I try to telnet from my computer to any of the other IP addresses (192.168.11.2) it times out.
I have the following static routes set:
! ASA (full config in attached file)
route inside 192.168.11.0 255.255.255.0 10.30.10.20 1
route inside 192.168.10.0 255.255.255.0 10.30.10.20 1
!R2
ip route 192.168.10.0 255.255.255.0 192.168.11.1
!R1
ip route 10.30.10.0 255.255.255.0 192.168.11.2
More config for all three in the attached file.
Please let me know if there is any other config I can post that would help.
Thanks!
-S
  • WAN Routing and Switching
182
