07-31-2009 06:25 AM - edited 03-04-2019 05:37 AM
Hi Netpros,
I have a Catalyst 4510 L3 swtich (192.168.212.1) and are using static routes, I have no default route configured.
My problems is this - i have a directly connected 10.100.100.0 /24 network and I need to add a static route to 10.118.13.0 /24 network via 172.168.8.2 The routing table shows the following :
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.100.100.0/24 is directly connected, Vlan10
S 10.118.13.30/32 [1/0] via 172.16.8.1
the static route has been entered as ip route 10.118.13.0 255.255.255.0 172.16.8.1
When I ping from the Catalyst switch to network 10.118.13.0 It works fine, however when I ping from the 10.118.13.0 network to 192.168.212.0 network (Catalyst switch) I get TTL expired messages - its like I have a routing loop and the cause of the problme I think is becuase of the directly connected 10.100.100.0/24 route?????
I could be wrong - any takers on trying to figure this one out with me?
thanks.
rod
Solved! Go to Solution.
07-31-2009 06:54 AM
Hi Rod,
I don't think there is any relation between VLAN 10 and your issue.
You need to make a hop by hop routing table check starting from the host on 10.118.13.0 subnet:
- You check the routing table to find the outgoing interface to join 192.168.212.1.
- If the nexthop is the expected one, do the same check on the nexthop up to the destination.
This way you should find a wrong entry on a router along the path.
You can also do a traceroute from the host.
Laurent.
07-31-2009 06:54 AM
Hi Rod,
Laurent.
08-02-2009 11:26 PM
Thanks Laurent, by looking at the basics (routing tables) I was able to reslove my problems.
One of my hops on the way didn't have a route to the 192.168.212.0 network - although I could have swore blind I added it !!
thanks.
rod
