10-06-2005 06:10 AM - edited 03-03-2019 10:40 AM
Hello, I'am Carlos, I'am from Venezuela and my english is not very good, but i need your help. The problem is that i have a cisco WS-C6506 with this configuration:
interface Vlan1
ip address 161.196.136.129 255.255.255.128 secondary
ip address 161.196.73.1 255.255.255.128 secondary
ip address 161.196.204.1 255.255.252.0
ip access-group acl-Proteccion-Voz-IP out
ip helper-address 161.196.64.40
no ip redirects
no ip unreachables
ip nbar protocol-discovery
ip route-cache flow
i have a tacacs server (161.196.17.19), but only i can do ping with a ping ext with ip source 161.196.73.1. My ask is, how i can do to ping to the tacacs server without extended ping
10-06-2005 07:29 AM
If you do a standard ping it will default to use the primary interface IP as the source address. If extended ping specifying the source as 161.196.73.1 does work then it demonstrates that you have a route to the server and that the server has a route to 161.196.73.0. If a standard ping does not work, while you still have a route to the server it indicates that the server does not have a route to your primary IP address. I suggest that you check the server and whatever routers are in the path from the server to your 6506 and find which one(s) does not have a route to your address.
Does the network run a dynamic routing protocol or is it set up with static routes?
Rick
10-07-2005 04:25 AM
Hello, Thanks you, Yesterday I was checking the problem and discovered that the problem were a firewall, the ip address 161.196.204.1 was aditioned and the problem was resolved.
10-07-2005 07:51 AM
Carlos
Thanks for posting to indicate the solution of the problem. It helps make the forum more useful when we can see about a problem and see what the solution was.
I encourage you to keep participating in the forum.
Rick
