Community Member
Routing query
I have an MPLS link at one of the location and wanted to utilize the link for two offices in same premises with LAN segmnt as 192.168.130.x  with default gateway of same range 192.168.130.5
Can we use the same router as gateway for other office where LAN range as 192.168.25.x.
Pls share your responses
Routing query
Hi Nihit ,
Yes you can. You have to create a different vlan that will accomodate the 192.168.25.0/24 prefix, and then create a subinterface on the WAN router's LAN interface.
Dan
Routing query
Hi Nihit,
If I understood your netwoek topology correctly, you can do this by configuring a new subinterface to your router for the other VLAN 192.168.25.x.
Lets asumme that you allocate the IP 192.168.25.254 to this sub interface of the router.
This IP will be the default gateway for the users of the 192.168.25.0/24 range.
The other subinterface will be used for the 192.168.130.x users.
Hope that helps,
Vasilis
Community Member
Routing query
Hi Vasillis & Dan,
Thanks for your response  !!!
The IP 192.168.130.5 is configured on the WAN Link . In case ill configure a new subinterfce will the traffic from source as 192.168.25.X able to  reach the servers.
Let me check.
Routing query
Hi Nihit,
Could you describe in more detail your setup ? Where is 192.168.25.x is currently connected, what is the current config of the WAN router, and also what is the phisical topology related to the wan router and the 192.168.25.x ( office ).
Dan
Silver
Routing query
yes you can... if you are using vlans on your topology, the only thing you should do is configure a new subinterface with an ip address of the another segment, if you have not vlans, configure the ip address for the DG like secondary address
Gerardo
Posted by WebUser Gerardo Guerrero from Cisco Support Community App
Silver
Routing query
Create a secondary IP address on the same interafce that has IP address of 192.168.130.5
Posted by WebUser Neeraj Jagga from Cisco Support Community App
Silver
Routing query
NJ-R1(config)#int fa0/0
NJ-R1(config-if)#ip address 192.168.130.5 255.255.255.0
NJ-R1(config-if)#ip address 192.168.25.1 255.255.255.0 sec
NJ-R1(config-if)#ip address 192.168.25.1 255.255.255.0 secondary
Silver
Routing query
We featured your question on our page. Check out the responses here http://www.facebook.com/CiscoSupportCommunity/posts/227046674066710
Posted by WebUser Cisco NetPro from Cisco Support Community App
363
