Routing question (OSPF)
i have 3 AS -my 65334 and ISP's.
I received 2 routes- 10.20.24.0/24(AS3216) and 10.20.48.0/24 ( AS2854).
Inside AS i use OSPF.
Here parts of configs-
Router R1-
router ospf 1
log-adjacency-changes
network 1.1.1.0 0.0.0.255 area 0
network 172.22.22.0 0.0.0.7 area 0
redistribute bgp 65334 subnets
router bgp 65334
no synchronization
bgp log-neighbor-changes
network 172.22.23.1 mask 255.255.255.255
timers bgp 5 20
redistribute ospf 1 match internal external 1 external 2
neighbor 172.30.0.66 remote-as 3216
neighbor 172.30.0.66 soft-reconfiguration inbound
no auto-summary
R1#sh ip route 10.20.48.0
Routing entry for 10.20.48.0/24
Known via "ospf 1", distance 110, metric 1
Tag 2854, type extern 2, forward metric 2
Redistributing via bgp 65334
Advertised by bgp 65334 match internal external 1 & 2
Last update from 1.1.1.1 on GigabitEthernet0/1, 00:17:12 ago
Routing Descriptor Blocks:
* 1.1.1.1, from 172.22.23.2, 00:17:12 ago, via GigabitEthernet0/1
Route metric is 1, traffic share count is 1
Route tag 2854
Router R2-
router ospf 1
network 2.2.2.0 0.0.0.255 area 0
router bgp 65334
no synchronization
network 172.22.23.2 mask 255.255.255.255
timers bgp 5 20
redistribute static
neighbor 172.16.200.194 remote-as 2854
neighbor 172.16.200.194 soft-reconfiguration inbound
no auto-summary
R2#sh ip route 10.20.24.0
Routing entry for 10.20.24.0/24
Tag 3216, type extern 2, forward metric 2
Last update from 2.2.2.1 on FastEthernet0/0, 00:16:21 ago
* 2.2.2.1, from 172.22.23.1, 00:16:21 ago, via FastEthernet0/0
Route tag 3216
From router R1 network 10.20.48.0/24 is reachable via 1.1.1.1. But i've direct
connection between R1 and R2.
Same with router R2 and network 10.20.24.0/24.
How to use direct link between R1 and R2?
R1#sh ip ospf ne
Neighbor ID Pri State Dead Time Address Interface
192.168.16.1 1 FULL/DR 00:00:35 1.1.1.1 GigabitEthernet0/1
172.22.23.2 1 FULL/DR 00:00:34 172.22.22.2 FastEthernet1/1
R2#sh ip ospf ne
172.22.23.1 1 FULL/BDR 00:00:31 172.22.22.1 FastEthernet2/1
192.168.16.1 1 FULL/DR 00:00:34 2.2.2.1 FastEthernet0/0
Re: Routing question (OSPF)
Mike,
Make sure that the ospf cost of going over the direct link between r1 and r2 is lower than the cost of going via the third router. It looks like it is not currently the case.
Hops this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
HAROLD, Thank you for reply!
Here info about costs-
R1
R1##sh ip ospf int
GigabitEthernet0/1 is up, line protocol is up
Internet Address 1.1.1.201/24, Area 0
Process ID 1, Router ID 172.22.23.1, Network Type BROADCAST, Cost: 1
Transmit Delay is 1 sec, State DROTHER, Priority 1
Designated Router (ID) 192.168.16.1, Interface address 1.1.1.1
Backup Designated router (ID) 10.20.46.4, Interface address 1.1.1.2
FastEthernet1/1 is up, line protocol is up
Internet Address 172.22.22.1/29, Area 0
Process ID 1, Router ID 172.22.23.1, Network Type BROADCAST, Cost: 10
Transmit Delay is 1 sec, State BDR, Priority 1
Designated Router (ID) 172.22.23.2, Interface address 172.22.22.2
Backup Designated router (ID) 172.22.23.1, Interface address 172.22.22.1
R2
R2#sh ip ospf int
FastEthernet2/1 is up, line protocol is up
Internet Address 172.22.22.2/29, Area 0
Process ID 1, Router ID 172.22.23.2, Network Type BROADCAST, Cost: 10
Transmit Delay is 1 sec, State DR, Priority 1
FastEthernet0/0 is up, line protocol is up
Internet Address 2.2.2.201/24, Area 0
Designated Router (ID) 192.168.16.1, Interface address 2.2.2.1
Yes, as you supposed the link between R1 and R2 have greatest cost ( 10 instead 1 for another interface).
I can manualy decrease cost for link R1-R2 and increase cost for others interfaces.
But! AS3216 and 2854 have a lot others routes which come to R1 and R2 and redistribute inside my AS5334. I want to use link R1-R2 only for communications networks in AS3216 and 2854 between each others and for backup purpose( in case of MEN failure).
Do you think changing cost can affected only for communications networks in AS3216 and 2854 between each others ( they will use link R1-R2 instead for example R1-MEN-Router-MEN-R2)?
You could use MPLS TE to make sure traffic between AS3216 and 2854 go across the direct r1 to r2 link.
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
100
